Ethernet Type & Length
Posted by: Mr Frog on 06 August 2014
Hi
tried searching the forum and posting on this subject a while back and didn't really find what I was looking for. So hopefully some kind person will be able to assist this time around ![]()
My router and NAS are on the same HiFi rack (different shelves of course) as my other kit. This means that the bog standard Ethernet cables are 'too long' and I wondered about the feasibility of using much shorter ones ....... or if that is detrimental to the SQ etc. For example, the Ethernet between the router and NAS could easily be a mere 25cm whereas the one leading from the Naim ND5XS is okay with the standard 1m cable.
Alternatively should I simply coil them up and use cable ties?
Furthermore, what specific Cat type (5e, 6, 7 ...) of Ethernet should I be using?
Many thanks in advance
