ND5XS and Usb sticks
Posted by: PTPlayers on 08 August 2014
Hi , does  anyone know if the ND5XS or NDX will support a 128gb usb stick  in the front port ?
Thank you
Posted on: 09 August 2014 by Huge
You could try searching the forum.
I believe someone was successfully using a 128Mb SD card in a card adapter with one of the Naim Streamers, but that the indexing was very slow.
Posted on: 09 August 2014 by Mr Fjeld
Huge is right. I have a few hi-res albums on a sd-card and a card adapter. And yes, indexing is a little slow. Sounds brilliant though!
Ops, forgot to say I use a Superuniti.
Posted on: 09 August 2014 by Bluetorric
Yep, I can confirm that I use a 128gb stick in the front USB port of the ND5XS, sounds very good too......
Posted on: 09 August 2014 by PTPlayers
Thank you Blue
Yes, I seriously rate the ND5 XS.
In my system, I now hear very little difference between using a USB stick as the source, and getting the data from my NAS drive via Ethernet.  In fact the difference is so small that I'm not sure whether it's real or whether I hear it just because I expect to hear it!
I have however, done a lot of work to reduce RFI in my system, as where I live it seems to be quite bad, and this has more effect on the network as a source than it does on the USB source.
