Album artwork moving around on nStream/Asset
Posted by: DaveM6 on 12 August 2014
Hi guys, I am currently using assetNAS v4 on an AssetNAS NAS and the latest version of nStream, and ripping using DBpoweramp CD ripper. Never had any issues with nStream displaying the album artwork before, but for some reason the artwork displayed under the 'All Artists' list in nStream has started to display incorrectly. i do have some albums with no artwork which I will sort with MP3Tag at some point so don't know if this is part of the problem.
The problem occurs when I first access nStream and also when I move from the 'All Artists' list to a specific album and back again. What happens is that some of the album artwork displays incorrectly. For example, the albums with no artwork, display the artwork from other albums. And on some of the other albums which displayed correct artwork now display the wrong artwork, e.g. The Killers shows artwork for Everything but the girl! But this then might change again when I move between 'All Artists' to an album and back again. For example, The Killers now shows artwork for Maroon 5! This only happens in the 'All Artists' list. The artwork is correct against each album.
I have searched on this forum and the DBpoweramp forum for similar problems, so have checked that the correct .jpg folders are showing in the music folders, refreshed/rescanned Asset, looked at Asset configuration and cleared the cache on nStream but the problem persists. Not sure if it is nStream or Asset, so will post a query on the DBpoweramp forum depending on responses here.
Streamer is an NDX - software v3.13. Really should upgrade to latest version!
Any guidance/help would be much appreciated.
Cheers.
Dave
