Audio Network Config Discussion Continued
Posted by: Huge on 18 August 2014
Originally Posted by Simon-in-Suffolk:
Huge
My comments
L2 Unmanaged - passes Broadcast data packets to all active ports, but 'learns' to pass data packets that specify an endpoint only to the port where that endpoint is connected.
The switch send the broadcast frames out of all active ports on the same network or VLAN . If a switch does not support VLANs it will send the broadcast frames out of all active ports.
A switch learns and constantly checks the association of Layer 2 network addresses to specific ports so it knows which ports to send the frames to. A broadcast frame has a specific broadcast destination address which is understood as a special address by the switch.
For many consumer switches multicast frames are handled the same way as broadcast frames
A switch is a layer 2 device and handles Ethernet frames and not packets.
L3 Managed - allows the network admin to specify which classes of data packet (selectable using both Layer 2 and Layer 3 characteristics) are passed to which port.  Is the programming done by port, by endpoint ID or by either?
(I know L2 Managed also exist, but for this use they seem to be a less good compromise - they still need programming, but don't offer identification of packets on Layer 3 criteria).
Layer 3 refers to the TCP/IP transport layer and works with data packets. A L3 packet is encapsulated within a L2 frame.
A layer 3 function includes routing. Routing allows the flow of  data packets  from one network to another - such as your internet access network to your home LAN or between VLANs on your home LAN.
Packets and frames have source and destination addresses. Packets have source and destination IP addresses and frames have source and destination network or MAC addresses. A network or MAC address is only deliverable within the same network or subnet. For the data to pass between networks or subnets the source and destination IP addresses are used and the router handles this function.
Essentially the layer 2 network address is used to deliver the frame to the router and then the router looks at the IP addresses to see where to send the packet.
A 'Layer 3 switch' is a combined switch and router.
The term of managed and unmanaged largely doesn't define the functionality of the switch but typically refers to the ability to 'manage' the configuration ie bespoke its operation in some way - I think what you refer to as programming. The programming can be applied to many different aspects of the network, frames and packets - and is subject to the capability of the switch
I hope that helps
Simon
Thanks Simon,
Most of my errors were in terminology rather than understanding.
Most of my work was in layer 7 (but also specifying which L6 and L5 protocols to be used), I learnt just enough of the other layers to be able to explain to the experts what I needed the network design to achieve, and to understand and confirm what they designed.  This is easier face-to-face than via forum posts, so please bear with me.
Last thing I did was a desktop virtualisation project in a legally regulated international environment.  The VLAN design for this gets, well 'interesting'; particularly trying to explain what constitutes 'local'.
I had missed the point about a router being required to cross subnets (which is why of course it's called a router - d'oh!).  I also assumed that L3 managed capability was rather more defined.
I did realise that cheapo devices usually treat broadcast and multicast the same way.
Thanks again I will no doubt have more questions.
The diagrams and content for the guide site are now fleshed out, I'll get them wrapped in the http design layer when my friend can do so.  Then I'll post a uri here so you can review it.
Posted on: 18 August 2014 by Simon-in-Suffolk
cool - speak later
Posted on: 18 August 2014 by DaveBk
Is the intent here to collaborate on a networking guide with a specific bias towards getting the best out of Naim Audio's streamer family? It's a very worthwhile goal, but difficult to achieve in my opinion given the diversity of network topologies and equipment out in the wild. The question is whether to attempt to educate the end user to an extent that they will be able to design and implement a solution that meets their needs or propose a set of recipes that can be implemented without any real understanding of the technology involved.
Happy to help QA anything. My detailed networking knowledge is very rusty compared to Simon's, but I often have to 'sell' technical concepts to a non-technical audience so have some relevant expertise.
Dave.
Posted on: 18 August 2014 by Huge
Dave.
The intent is a to make a guide that can do both, well to a degree at least.
It will provide three simple layout diagrams, each with an outline of the reasons why it's an improvement on the previous one.
I also intend to provide a simplified 'how to' on amelioration of RFI and some notes on mains issues.  These will give a very broad outline of the technical reasons.
All the explanations will be in a qualitative manner.
OK, I've just finished the photography as well.
Another re-read of the content and I'll be set.
Posted on: 23 August 2014 by Huge
Here's a link to a PDF version out for review.
https://docs.google.com/file/d...rl1ykVDNkQks0eUJ6aVU
(I think it works OK, Google drive behaves differently on the author's account than to guests / others).
All comments welcome, even if it's "Completely wrong - This is what you should have done..."
Posted on: 23 August 2014 by Mike-B
Excellent,  simple & no techo-babble
I would be concerned about only listing Cat5 & why some Cat5 & other 5e - apart from bandwidth,  no real difference but it might add unhelpful confusion factor.  Maybe better to list all the Cat's that are UTP & explain the differences & benefits.(why not go straight to Cat6 & forget Cat5 ???)
Not so sure about a ferrite at each end of the individual ethernet sections. Reading the pro cmpy papers from those that do advocate ferrite on ethernet seem to put just one at the product devise end & not the switch/patch.
Do we need a drawing of an STP network & show the UTP dis-connector in that section
Do we need the section on a DC filter,  as you know I am a fan & user of these filters,  but IMO it does not fit in with this LAN subject  (frightens the horses)
Thanks Mike.
Yes I do think a short note explaining that it's "Cat5 or anything above" would be a good idea.
Ferrites on both ends - not needed for properly screened network devices, bit where a cheap unscreened device is in use this can inject RFI.  I'm not entirely sure how effective they'll be here, but I'd rather advise the conservative route than risk people rubbishing the whole thing just because they didn't use 5 more ferrites.
The STP diagrams - Yes there's a <ToDo:> note for me to add them.  I think I'll do this as an appendix to avoid even more frightened horses
The DC Filter - I think I'd like to keep it as it is relevant from the interference perspective (the large electrolytics are actually quite good RFI filters as well), but yes again move to an appendix to isolate it from the mainstream info..
Thoughts on the appendix option?  Appendicitis perhaps? Appendectomy needed?
Revised version
https://docs.google.com/file/d...rl1ykajNJZU56ZnZDaGM
Posted on: 23 August 2014 by Simon-in-Suffolk
Huge
Very good.
My comments:
1) Perhaps use device symbols - such that you have used for the NAS and PCs  for the broadband router and switch rather than network diagrams symbols - as drawn using network diagram symbols the router is incorrect.
2)You show a picture of a transmitter tower for RFI. I think this might perpetuate the common mis understanding that RFI is linked to radio transmitters! For the most part this is not the main cause of RFI that we have in our homes. So you could show a collage photo of LED lighting, dimmer switch, solar panels, PLA etc and a 'scope picture of HF hash perhaps on a mains sine wave??
3)Finally you show Cat 5 cable - I think for 10/100Mbitps line speeds current wisdom is to recommend 5e as a minimum, and usually aligns to what is generally available.
Good guide.
Simon
Simon,
1  Yes, got the wrong router type ('Broadband Router' rather than 'Router + Broadband ADSL TA').  The other problem is that I don't have suitable diagrammatic representations that can distinguish a router from a switch.
        I'll have to have a good think to find a workable solution for this.
2  Yes, it's just what I could take a pic of (to avoid copyright issues I take the pics myself, and also I just like that pic!).  OK then, I'll try collecting suitable objects.  I do have a pic of a washing machine control panel (but that's just boring, not in the least artistic or photogenic!).
3  Yes agreed.
Posted on: 24 August 2014 by Mike-B
Hi Huge -  my t'up pence worth
I’m concerned you have too much detail in the STP section with all the diagrams. Maybe a single diagram to show the principle of UTP isolation with the right text would be less (is more)
Re the “right angled” adaptor – what I got hold of are as rare as rocking horse pooh. They seem to be exclusive to or are only sold by Lindy in UK.
I would advise to say …. broken by an unshielded coupler to join two lengths of STP, or connect the STP cable to the earthed (grounded) device with an unshielded female to male adaptor. …..
There is a risk with all adaptors as some are crossover devices, so do you say something on that.
Also need to use either "screened" or "shielded" words,  not both,  I would prefer shielded as thats what the ethernet industry uses.
The photos of STP cables do not clearly show the main identifying RJ/E-45 connecting shield around the plug end.
Finally I wonder what Naim are gonna say about this & if they are happy to allow it to go out via the forum.
I will get a whip round organised after you get finished.
Meanwhile I'm out for the day - watching F1 on a huge TV with audio via some megabuck Linn amps & speakers.
Huge, I had something in mind last evening,  but grape juice from Stellenbosch caused memory loss.
In the RFI section maybe to call it RFI & EMI
We also have (maybe more problematic than RFI with UTP cables) alien crosstalk - the induction of noise from adjacent cables.  Alternating current in power cables produces electromagnetic fields around the cable & can induce a current flow in adjacent Ethernet cables.
Posted on: 24 August 2014 by Huge
Originally Posted by Mike-B:
Thanks Mike
Problem is that using words people would have to actually understand, rather than follow the particular diagram.  I think I need to use a better explanation as to which diagram to pick.  I'll put this as a precursor paragraph in Appendix A; a 'Read This First' paragraph.
This is why I show the cable-cable coupler solution not a male - female RA adaptor
Good point that I missed, I'll include this (most switches and routers will actually work this out and function perfectly normally anyway, but still worth mentioning)
Yes, very good point I'll normalise this
Last one was done with flash (it was late in the day), I'll try to do one by available light, it should be clearer.  I'll try to do this with the other Product shots that Simon has suggested.
It's specifically not Naim specific, and doesn't mention any equipment manufacturer, I wasn't planning to post it directly on the forum.  If Naim want, I can easily produces a customised version (and allow them use of the copyright - I'm an officer of Cyan Ellis Ltd. so can I authorise this).  They can then post that if they want.
Ta, publicising it may help some people simplify their set up and remove problems.
Spa is such a great track; Eau Rouge would scare the hell out of me in the dry never mind wet as it was yesterday!
Posted on: 24 August 2014 by Iver van de Zand
nice doc Huge, I am interested in this topic ... going to study your doc now
Ah, the Stellenbosch Floral Zone!  Chenin Blank, or Zinfandel by any chance?
The RFI / EMI point is a good call to include in passing.
Not so sure about specifically mentioning 'alien cross-talk', I think that's too technical an argument for this discussion.  A suggestion about following general good cabling practice (including not having close parallel cables etc.) is worth including.
Pinotage from Simonsig.
D'oh,  I was thinking Pinotage and wrote Zinfandel, Zinfandel is California of course (not grown in SA to the best of my knowledge).
Zinfandel is produced in SA,  but nowhere as prolific as California or Italy were its called Primitivo.
Its not an easy wine to produce as it requires special harvest techniques, the grape bunches ripen unevenly; some grapes on the bunch can be mature, some raisined & others still green.  This adds significant production costs & results in high retail prices over other wines.
Mike, interesting, I didn't know that.
Posted on: 24 August 2014 by Simon-in-Suffolk
Huge, regarding EMI/RFI well of course the effect of coupling is always as EMI, and it is the higher radio frequency elements say above 100kHz that are typically referred to RFI.
 so interference could be categorised a low frequency such as in earth loops, ultrasonic and RF... Possibly.. I suspect over cooking it though.. So perhaps something like " RFI can be caused by electric or magnetic coupling from sources producing energy at radio type frequencies"?
Posted on: 24 August 2014 by Mr Frog
Huge, great guide
Just one query which may not be particularly be relevant is in relation to the length of Ethernet cables and whether it makes any difference. If several items of kit (routers, switches, NAS, streamer etc) are located close to each other, is it okay to use short Ethernet cables (e.g. 0.25m) rather than coiling up a standard length patch cord or does this cause issues with particularly short lengths of Ethernet? I seem to recall reading somewhere that short Ethernet cables were not recommended but I can't understand why. As a layperson, to me shorter cables are neater and I would thought less likely to be effected by RFI but I'm certainly no expert in this area and it might be more problematic.
Some of my kit is close to each other and so it seems logical to reduce the amount of surplus 'coiled' cable if possible but not at the expense of causing issues with the system. Presumably if short is okay, I still need ferrite chokes at each end of the Ethernet To reduce RFI/EMI or whatever
Posted on: 25 August 2014 by Simon-in-Suffolk
Mr Frog, from a networking point of view short patch leads are completely fine. From an EMI point of view there is potentially the issue that the encoded carrier is received with more energy with a short lead rather than a long one, due to less losses in the cable. Also any common mode noise from the switch etc will have more energy at the receiving end with a shorter patch lead.
However I suspect the comparative difference in impact between different short lengths of patch lead, say <10m will be on the  subtle side if noticeable at all.
Posted on: 25 August 2014 by Mr Frog
Thanks Simon
Based in that, I'll stick to my standard length ones and put loose coils on them tied with a cable tie if that's ok
thanks again
Posted on: 25 August 2014 by Mike-B
I use short cables as my player is located nearby the cabinet that houses NAS, switch & wireless hub.  The downside is it gets cramped up with a lot of mains & DC power cables.
Because of this & the EMI issue Simon speaks of, it is the one reason I went with SPT (Cat7) (correctly grounded of course)
My early training & work in marine electrics required most all cable runs to be in close proximity, DC & AC with all sorts of volts & Hz, radio & radar & shielding (conduit, cable or mu metal) was mandatory as was ferrous (ferrite) clamping.  In those days - long before Ethernet had been invented - it was not so well categorised, but I now know it as EMI & RFI & the Ethernet related word alien crosstalk.
This training kinda sticks in a person’s brain tool box & throughout my hifi journey, concern for this type of interference has remained.  All my mains cables are shielded as are the Ethernets, that way I sleep easy & try as I might, I can’t hear anything negative.  Personally whist short lengths of Ethernet might have a theoretical potential problem, in practice in home hifi its irrelevant.
Posted on: 25 August 2014 by AntonD
Originally Posted by Huge:
Many thanks for going to this effort. I think it's an excellent document.
Maybe Naim forum administrators can add the doc to the FAQ section as this will definitely help both newcomers and existing streamer users.
Well done!
