n-Stream not streaming from vTuner
Posted by: Sven on 02 September 2014
Hi,
Until recently I was able to stream specific radio station from vTuner with n-Stream to my UQ2.
Altough the station is operational and can be played on PC and visible on vTuner and n-Stream, massage received on UQ2 is: Station unavailable.
Any suggestions ?
Sven
Posted on: 02 September 2014 by osprey
Sometimes the radio stations change the actual URL of their stream and it takes a bit time before vTuner update their database. You could contact their customer service. Which station are you trying to connect?
Posted on: 02 September 2014 by Sven
Atlanta Blue Sky - Jazz colors.
Posted on: 03 September 2014 by osprey
I just tried to connect this station but I had no luck. I also tried to add this station to the Added Stations list but that did not help either (sometimes it does). It might be that the the station has restricted the use of its stream but that is odd since you have previously managed to listen to their program (but these kind of policies can change also). If you can solve this problem please post about it since based on the samples I heard through the web browser this could be an interesting station.
