HD Tracks UK appears active
Posted by: Dan43 on 09 September 2014
www.hdtracks.co.uk  home page just came online for me is anyone else getting it also?
Purchases are in £ sterling.
Posted on: 09 September 2014 by Paul Meakin
It works for me too.
I did have to re-register though, it didn't take the login details that I had for the American site (which I now can't reach due to being redirected).
Posted on: 09 September 2014 by nudgerwilliams
Press release here:
http://www.theaudiobuzz.com/20...-the-united-kingdom/
Together with Qobuz, these things are like buses :-)
Posted on: 09 September 2014 by Aleg
On the German .de site, prices are 20% higher than on Qobuz, combined with the somewhat doubtfull reputation of HDTracks, a no-go for me.
Posted on: 09 September 2014 by AS332
Expensive though . Some of the albums that I have been looking at cost $24.77 on the US site are £24.50 on the UK site .
Posted on: 10 September 2014 by 0rangutan
Also, Deezer for Sonos is launching lossless streaming at a bargain price.
Great to see new options emerging.
Posted on: 10 September 2014 by Harry
Yeah. That sounds about right and was predictable.
Posted on: 10 September 2014 by Mike-B
I'll just keep buying from HDT USA
Better pricing than Qobuz & the supidity of the $ = £ with HDT.co.uk
Many more albums available  than HDT.co.uk & Qobuz
IP subdefugue stops the HDT.co.uk redirect
I guess sooner or later competition will get the pricing down to typical CD levels,  hopefully even less considering manufacturing, materials, shipping & warehousing are not required with audio files.
Posted on: 10 September 2014 by Steve J
What's the best IP masking software Mike?
I've used a few Steve & TBH not much to choose between them,  they are mostly simple apps to help with security when you are working on a public wifi hotspot & are all you need for getting "regional restricted" downloads.  A few use a very complex routing around thousands of locations & are overkill for simple IP foolery,  these have a problem with being very slow so the download part goes on a bit.
At the mo I'm using Easy-Hide-IP,  but have yet to try it with the new HDT to UK divert system in place so not sure how that will work out when I next log in with my UK e-mail & PW.  (& I don't have any albums on my wish list to give it a try)
I'm also working with a buddy in USA & are playing around with ways to work something with a US e-mail address in my name - & he with a UK e-mail address.
Posted on: 10 September 2014 by Simon-in-Suffolk
You need to use an internet proxy service. I use UK2.net. It effectively creates a tunnel from your router or PC to the remote proxy service in another region that then has a public IP address that is associated with that region such as the US.
There are some free proxy services around, but have poor performance in my experience.
Posted on: 14 September 2014 by Mike-B
Originally Posted by Mike-B:
.............   At the mo I'm using Easy-Hide-IP,  but have yet to try it with the new HDT to UK divert system in place so not sure how that will work out when I next log in.
Tried Easy-Hide-IP - went to HDT (USA) no problems (not diverted to UK), opened my US account & downloaded some albums that are not available on HDT.UK & were about 30-40% cheaper than Qobuz
It seems to be one of the better IP security operators with professional install process & registration that gives confidence
They have a large selection of country locations to choose from & either system selectable or user selected actual IP addresses.
Problem is (like many of them)  very slow www access,  so much so that whilst I would use this for music downloads, I would find it very frustrating if not impossible using it to hide my IP when using a wifi hotspot.
So I have tried it & thanks but no thanks
Final point is its not easy to uninstall, not impossible, but need to be IT savvy.
Posted on: 14 September 2014 by Simon-in-Suffolk
Mike,  just out of interest why would you want to hide your assigned IP address when you are on a wifi hotspot? If you need to use secure comms, just make sure the web service you are talking to uses transport layer security and/or secure sockets (the key symbol on a web browser),  alternatively use a secure VPN into your concentrator that is behind the internet (ie a commercial encrypted web proxy service) . Proxying your IP address doesn't necessarily make your comms any more secure...
I use proxies here to circumvent geo location based on your regional assigned IP address, effectively usually defined by the ISP being used... and that will apply equally to a public wifi hot spot as to a private internet access.
Simon
Hi Simon, why hide my IP in public wifi hot spots ???
In my case, maybe a touch of paranoia. I don't use hotspots around UK but do frequently when overseas (usually 3-5 trips per year).  I once ended up with a badly compromised laptop that manifested itself after using a hotspot just once during a trip. I'm not sure how or why & I am 99.9% convinced I did not do anything wrong to cause it. That experience took some sorting out & I am not prepared to go that way again,  I was led to believe these IP hide progs can help in this.
Tell me I am misguided in this respect,  I will take it as good advise.
