UnitiServe Blinking
Posted by: Sdan on 19 September 2014
Came home from being gone 4 days and mu US is blinking. Cannot get it to stop. Any advice?
Tim
Posted on: 19 September 2014 by Jan-Erik Nordoen
Have you switched it off and tried restarting? If the blinking remains, it's time to call your dealer.
Posted on: 19 September 2014 by KRM
...and get the dealer to try it with a different power supply before he sends it to Salisbury. I'm on my third.
Keith
Posted on: 20 September 2014 by Kiwi cat
Hi Keith
do you mean the power cable or something in the Unitiserve box that has been failing?
Posted on: 20 September 2014 by Sdan
The US box is not blinking. WHen I press the lighted (blinking) Naim logo, it will not power off. I have shut it off and restarted with the same results. I will contact my dealer. Thanks.
Tim
Posted on: 20 September 2014 by The Meerkat
Tim
Tim...I had exactly the same thing happen to my UnitServe SSD. It had to go back to Salisbury, which resulted in a new power supply, a new front panel logo and several other components. Two weeks after I got it back, it broke again. In the end I sold it!
Let Phil Harris (Technical Support Manager) remotely access the UnitiServe via your computer. Phil is very helpful, and very knowledgable. If it's software related, Phil may be able to sort it.
Posted on: 20 September 2014 by Bart
Tim
If the box itself were blinking, and not just the logo, something really odd would be going on!
