HDX and Qute2 multiroom
Posted by: Cbr600 on 21 September 2014
Just wondered if anyone at Naim could comment on this.
I know that my Qute2 can use multiroom and can search for other streamers, but it cannot use multiroom to work with the HDX as its a server.
Seems a shame as i can play the HDX and qute, and it would be nice to be able to link the Qute to sync same music.
Any chance this could be done in a future software update, as it would be a nice option
Posted on: 21 September 2014 by DavidDever
You'd need another (192-kHz capable) Qute or Qute 2, as there is no shared software between NDx / Uniti and HDX / UnitiServe devices to enable synchronized zones.
The 192-kHz capability requirement insures that firmware version 3.22 will work on your device, which will unicast-proxy a 320 kbps MP3 stream in frame sync to other devices on the network. You can still select music from the HDX via n-Stream from the master proxy Qute.
Posted on: 21 September 2014 by Cbr600
Thanks David. I already use the music on the HDX and its NAS drive to feed the qute.
My query was about future potential to sync the 2 units as i understood Naim were working towards a single software to unite the serve and stream software
I believe that was on the app (control) side, not the core application (different software / OS / processor) on the devices themselves.
