Updating my ND5XS.
Posted by: fred40 on 29 September 2014
A bit confused updating my ND5xs. Must I use a usb cable one side in the computer and the other end by using a small usb socket at the back of the ND5xs or can ( must)  I  use the usb socket at he front of the ND5XS?
Posted on: 29 September 2014 by Mike-B
Use the mini-USB on the back - its marked as the upgrade point in the manual
The front USB is music only
Posted on: 29 September 2014 by hungryhalibut
You need a USB to USB Mini B lead.
Posted on: 29 September 2014 by fred40
Ok  Thanks
