Naim app for iOS - Version 4.1
Posted by: TJ on 29 September 2014
Hi All,
Thanks for the feedback on the release of 4.0, especially to those who were able to send detailed reports of their issues, it was a great help in tracking down some of the compatibility gremlins. A new version is with the Apple review team and will hopefully be publicly available sometime this week. Below is a list of changes and additions.
Tom
Fixed: Incompatibility with some pre 3.15 streamer code
Fixed: Incompatibility with playlists created on some old versions of n-Stream
Fixed: UPnP now playing screen now behaves better when playback started from product front panel
Fixed: Rovi results not handling accented characters
Fixed: Can't change volume after accessing Rovi
Fixed: CD player tapping track in play queue would not start it
Fixed: Popup menu occasional wrong orientation
Fixed: Hide settings input trim control if connected to a product that has no volume control (e.g. NDX, NDS)
Fixed: Support for CD player automation (ND5XS, NDX, NDS)
Fixed: Now uses correct background icon on FM input
Fixed: ensure "stay connected" setting is correctly saved and restored
Fixed: Crash related to very large cover images
Fixed: Can't press play queue menu buttons with iPhone 4
Fixed: iPad now playing screen text alignment issues
Fixed: sometimes could not stop/restart radio stream on now playing screen.
Fixed: Crash when rotating after style change
Fixed: Moving presets should be disabled for older products
Fixed: Queueing/playing tracks when not on UPnP input (refined process of switching to UPnP input)
Added: Send device type and iOS version as part of email version info
Added: Bitrate to iRadio browse list view
Added: Now playing screen now shows bitrate and sample freq for iRadio, UPnP and USB inputs
Added: Hi res graphics for new iPhones
Added: Album cover thumbnails on play queue in both orientations
Added: Build with iOS8 SDK
Added: Various new translations
Added: IP address now shown on product info screen
Changed: Welcome screen now uses Naim logo
Changed: disabled reset streamer function
Changed: Improved visibility of browse section headers
Changed: Fixed low resolution cover images being shown for some UPnP servers (requires image cache to be cleared)
