usb sticks not working on Ndac
Posted by: Claus-Thoegersen on 07 October 2014
Until my ns01 arrives from Naim hq, I use my old squeezebox receiver with Ndac. This is ok, but cannot play my 24 bit files.
But the ndac can, and it has worked earlier by using usb sticks, both with wav and flac files.
But now nothing works, with 3 different usb stick.
I have a usb stick, that is not recognized, but the 2 other sticks I have should work ok, but they do not.
One It is a 4 gb and the other is a 64 gb I used to use in my ns01 before I bought a nas. But now none of them work. They are recognized but the music on them does not start to play.
Fortunately the Ndac works fine with the coax connections I use, but I wonder if there is a fix I can try until my ns01 returns?
