Question about netgear switch set up
Posted by: Scooot on 15 October 2014
Hi,
i have just installed a netgear gigabit switch in my system and was wondering if all was ok.
The ports on the switch that the virgin media super hub 2 and Nas are plugged into are showing 1000 Mbps.The cable running to the nd5xs is only showing 100 Mbps.All cable is cat 5e.The system is playing fine and I have noticed that the new app seems to responding faster.
Is this correct or is there something amiss with the connection somewhere.
thanks scott
