Is there a Superuniti desktop client?
Posted by: Dunstan on 19 October 2014
Having googled around for quite some time I can't seem to find any way of controlling my Superuniti from my windows desktop pc.  I've got the iPad app but this is not always readily available and it would be handy to be able to select and play music or iRadio from my desktop.
Are there any solutions out there?
Posted on: 19 October 2014 by Andrew Everard
Have you tried the solutions in this thread?
Posted on: 19 October 2014 by Redmires
Yes, Namote from Beeka (Steve) is a perfectly formed little programme. It's not a Naim App replacement but is great for basics such as volume control and radio station selection.
Posted on: 19 October 2014 by Mike-B
It works with NDX too, albeit with limitations.  I just use it to change inputs - NAS, iRadio, USB, FMTuner & will select the iRadio list of preset stations.  When working in the study with my 2nd system it saves me going to the main system to change radio stations.
Posted on: 19 October 2014 by Dave***t
Thanks for the heads up, Andrew.  Hadn't come across that thread yet, very useful.
Edit: and of course thanks to Beeka, should he see this thread.
Posted on: 19 October 2014 by Dunstan
Thanks for the link.  I actually did come across it in my googling but thought there might be a more complete product out there.  I have now loaded Namote on my Windows 8.1 all-in-one desktop tablet thing from Dell and it runs fine although I had to enter the IP address manually and presumably that will change if I reboot the Superuniti (which I don't do very often).
Anyway, for a few basic controls and changing to something other than radio paradise it works fine.
Job done.  Much appreciated,
Posted on: 20 October 2014 by NeilF
If you go into the settings on your router it's usually pretty easy to assign a fixed IP address to anything on the network. I've got my NAS and my streamers on fixed addresses and it does make things easier.
Posted on: 23 October 2014 by PureHifi
Now that there is an Naim Android App, you can run an Android emulator on a PC..I have tried YouWave as an emulator and it works fine (although I have had limited time to fully pressure test it).
Posted on: 23 October 2014 by Andrew Everard
Agreed.
Posted on: 23 October 2014 by Redmires
Sir, you are a genius.
I've spent the last couple of hours running the app on my Windows 7 laptop and it works like a dream. My only gripe is that the artwork is low resolution, but it's the same on my tablet. Thanks again for the suggestion.
