Do I need to have any software running on my PC to run DTC for my unitiserve (e.g. to schedule a backup or promote a music share), or can I just connect the PC to the network and run DTC from the unitiserve?
My PC has had to be reconfigured and I have lost the shortcut that used to be on the desktop.
If I do need to install something, where can I get it from? I can only find the server upgrades to download on the naim website.
Thanks!
Posted on: 31 October 2014 by Dozey
Thanks again HH - although I couldn't see the picture I eventually worked out where it was. Phew!
Hopefully anyone in the future looking for the download will be able to find this thread to help them.
Posted on: 31 October 2014 by hungryhalibut
Not so Dozey after all then! I'm pleased you've found it. While you are in the DTC, set it to transcode your files to WAV on playback if you have them in FLAC, and if you have not done so already.
All my ripped files are in WAV. The only flacs are hi-res downloads which are transcoded to wav on playback as you suggest.
Life was too short to sort out the tags on WAV downloads!
