Superunity Boot Error
Posted by: Emmanuel Methivier on 05 November 2014
Hello.
I’ve a problem with my syperunity (i purchase it in may).
The problem is that i disconnect it for a week.
Today; i reconnect it to the electrical plug and it start and display « ERREUR 51 / F-Silicon boot error » and i can’t do anything.
What is the problem and what can i do?
Posted on: 05 November 2014 by ChrisSU
I've absolutely no idea. If your dealer can't help, I suggest you send your question to support@naimaudio.com
Good luck!
