Adjusting Volume on NAC 202 via N-Stream
Posted by: wbjnetwork on 13 November 2014
Hi All
First posting on the Naim Forum.
Have tried on several occasions to control the volume of my NAC 202 via N-Stream and failed.
My setup is:-
NDX powered by XPS2 DR
NAC 202 / NAP 200 with Hicap 2 DR + Napsc
CD 5 + Flatcap 2
Stream from a Synology DS212j
Currently use Av button on NAC 202 to connect to my NDX & CD button to CD player.
NDX Firmware 3.22
N-Stream latest 4.2
Ipad 3
Everything works fine apart from the Volume Control. I think I need a step by step guide even from resetting the NDX back to Factory Settings.
I have a mono cable connection 3.5mm to 3.5mm phono
Hope you can help.
Will
