NDX or HDX
Posted by: RoyleBlue on 26 March 2011
There are claims on the forum from Naim and their distributors that UnitiServe rips sounds better than rips done with non-Naim software so, if you believe that, you should factor it into your decision.
1000 cds is a lot of work to waste.
The threads are here:
There are so many combinations to consider.....personally I think I would go the HDX route particularly if it's an SSD version and quite new. Why? Well it doesn't rely on any sort of server to stream from and has the ability to play CDs, plus it can be upgraded with the nDAC.
I haven't heard the NDX, I'm sure it sounds great too......would be surprised if better than HDX/nDAC. Of course you could add nDAC to NDX although doesn't seem a favoured option. Will be interesting to see if either really does become a clear winner from SQ perspective.
Nice problem to have!
I would go with the HDX, it has so much more functionality and there is no reason why it should not sound as good or better than an NDX.
You should do a side by side comparison if only sound shall matter and then easily the bells and whistles of the Hdx vanish.
What D/A converters do the various NAIM components use? (eg, NDX/HDX/CDX2/CDS3........) I realize the analog circuitry (where present) makes a big difference also.
Buy both.
Then, you will know.
RoyleBlue,
Was in the same boat as you were, and went with the HDX. Standalone it sounds very good - close to a CDX2 as John says. I suppose if you prefer an external network attached storage drive, then the choice comes down to NDX + server software or HDX. If both are within your reach, I'd certainly go for an audition.
The ease of having a one-box solution for ripping, storage, etc. was the primary reason to go for the HDX. Never regretted it, I don't have to worry about various types of ripping software, settings etc....
Now, all I have to do is enjoying my music ![]()
Michel
The HDX is a fine one box solution but is too inflexible and inefficient. I stopped using a CD player over 6 years ago and everything but the codecs I have used aiff/alac and flac has changed constantly.
What will happen when UPnP and AirPlay go head to head - I don't know but I bet my files will still play.
Tog
It rips, it catalogues, it plays locally to above CDX2 standard and it serves up UPnP or NetStream. It has an iPhone app. It will have an iPad app. Its controllable from a web browser. It's going to get iRadio later this year as well as make mp3 copies for iPods etc. Its upgradeable with an XPS, 555PS or nDAC.
And no messing about with configuring third party servers, rippers etc.
I really can't think what else I would want or need it to do.
Hi John,
I could not have said it any better! I absolutely agree with you. However, since it's release there are certain people who always find a reason for bashing the HDX....
Michel
The answer is the ear of the beholder and anyone who is flipping a coin should go hear both side by side. For me the HDX offers everything I need/want plus a few things I never knew I needed but wouldn't be without. If contemplating as a one off purchase with zero percent likelihood of future upgrades (yeah, right...) the one that sounds best to the individual will be the one to take home. I suppose this equally applies if there are plans to add more boxes but once a DAC is sitting in the mix the differences are likely to be more about facilities and less about musical differences. It would not have been difficult for me to rig up a ripping and storing system. But it would have been yet another thing it would have taken me ages to get around to and would have involved endless tweaking, had the HDX not turned up and been totally convincing (to my ears) on sound quality/musical enjoyment. I'm more interested in a higher level DAC or DAC/Pre. I won't be holding my breath. To say the HDX is not highly versatile is selling it considerably short IMO.
RoyalBlue: Just rip to a NAS when the internal drive is full. And when (if) the internal HDX drive ever fails, get it upgraded to SSD.
Royle,
What is the rest of your system?
M
The obvious answer would be to listen to each ...which is true, and unhelpful.
The things I would consider would be:
1. Do you have a fileserver/NAS?
2. Are you happy ripping your CDs?
3. Are you OK with setting up an uPNP server?
4. Are you considering other digital 'transports'?
- DVD/BluRay/PC
5. Are you happy dealing with Networking.
Depending on the number of digital sources the NDX might be sufficient, or you might start thinking nDAC. The HDX, on its own wouldn't be sufficient. I might even start thinking UnitiServe + nDAC.
On the other hand if I found ripping CDs a pain; or I didn't have a fileserver/NAS; or I didn't want to get into setting up a uPNP server - I might think HDX.
That leaves sound quality ....be good to know what you think once you've had a listen!
Of course, some of this might help you decide whether you've got a good dealer!
Hope this helps,
M
Mine came with twin 500Gb HDDs. I spent plenty of ears on time with machines such as yours and concluded that what I could would get was at least as good as CDX2/XPS2 level. My finding (for me anyway) that rip to and playback from NAS was of equal quality/enjoyment was after the fact. It was at that point that two things happened. I had no use for the internal HDD for music storage and I first heard of the arrival of the SSD - which would have suited me much better and resulted in a period of self kicking. SQ wise the older machines were fine by me. Newer models with the updated sound card do sound a bit tighter and more detailed to my ears. It's an inexpensive upgrade. More RAM went in too, which was purely an operational enhancement.
