NAC202 unity Gain + AV2?
Posted by: v_j_r on 28 March 2011
Could someone explain how to set up the "Unity Gain" on the "AV" input of the NAC202 using a AV2 using its DIN reverse lead  please, i know that there are some explanations but they seem to go from here to there thankyou.
Regards.
Posted on: 28 March 2011 by Dungassin
https://forums.naimaudio.com/di...ent/2833539985312821
I posted this faq in January.  Basically, just follow the instructions.
Posted on: 29 March 2011 by rackkit
Regards.
"to switch on Unity gain once you're in program mode, you need to press the Mute button twice. Then exit program mode."
Posted on: 01 April 2011 by v_j_r
I thankyou for your reply i eventually found it by not actually reading all the blurb and looking at a section of the actions when certain button sequences are pressed by model, again many thanks.
Regards.
Posted on: 01 April 2011 by rackkit
No problems v_j_r
I took me a few searches before i could find and quote that reply from Richard Dane. The manual does a great of job of making something simple, almost impossible to understand. Well, to me anyway!
Rack.
Posted on: 01 April 2011 by Dungassin
Ah.  Sorry.  I obviously misunderstood your question.  My 282 was delivered and connected into my AV system by the dealer.  Can't find anything in the manual about altering the AV/Unity Gain Input, so I am grateful that rackkit has answered your question.
Yes if you disregard the all the reading and schroll down there is a graph showing by most models the effects on each by button press seqeunce, tis so much easier to understand!.
