Problem with iradio and naim choice
Posted by: Paul Stephenson on 24 November 2014
currently having some issues reported, we are working on it, update to follow asap.
Seems ok now?
Sorry Paul but its not correct , its showing stations, but only the listings as we had them a few months ago. - e.g. Naim Choice has lost the new BBC AAC feeds
See my post on the other thread for some more oddities!
Seems there could have been a rebuild today causing earlier issues, the weirdness you mention we think is related to that. Working on it.
Just checked, Naim Choice is restored & as far as I can see at a quick visual glance it appears to all be restored much as it was before = THANKS
Also my other problem of the bottom screen banner dissapearing is also now OK. This is probably an app issue & I have reported it to TJ
I think things are back to how they were before too. Naim's Choice now has Naim Radio again, as well as Radio Paradise 3 times! All Naim's Choice stations maintain 100% buffer now, except for BBC3. Oh, and the bit rate discrepancy on AVRO persists! Not that I'll be losing any sleep over all this - the stations I listen to are all listed at least once.
The 'bottom screen banner' thing is still an intermittent problem for me.....but I can live with it.
My banner vanished too. Killing the app and restarting bought it back. This iRadio malarkey is all liveable-with, but it's all rather too flaky for comfort. It should just work. You turn on Radio 4 on FM at 7 ready for the Archers, and it always works. iRadio should be like that.
.................. as well as Radio Paradise 3 times!
I really don't know why we have this, why would anyone want to select 128 instead of 320 ??
RP from NY is different sometimes so thats OK
If you live in an area with almost a wet string for internet connection you get download speeds which make 320k really difficult hence 128 and below.
Ha! A wet string! Luxury! We'd 'a killed for a wet string...
Wet string !!! by eke as like we had soggy string, it were only wet string when the roof stopped leaking, & then we had to share it, me an t' wife, 15 kids & t' mother-in-law all sitting round listening to the string, drip drip drip ................ ![]()
soggy string, luxury, we had to make a megaphone out of cardboard box (or home as we called it) to focus the sounds from down the road.
Tell the kids today and they won't believe you!!!
Well I have a wet plastic thing, with some rusty old copper inside it. But it works most days.
Since last night, I can now use all the Naim's Choice streams except for RP Naim Exclusive, which won't buffer above 30% and keeps cutting out. The other two RP 320 streams in Naim's choice work fine and maintain 100% buffer, which seems odd.
The banner seems to come and go at random.
I can still listen to the stations I want, so it's not a disaster - just a bit strange.
Pedant point: Copper does not rust! ![]()
OK, well it goes bluish green and crusty when it oxidises then! ![]()
Sorry Chris I couldn't resist. At least generally copper fouling is easier to deal with.
