Samsung plasma connection to NAC202
Posted by: domden on 25 November 2014
Is it possible to hook up the tv( 5 series 60 inch plasma)through the 202 in some way?
Absolutely skint at the moment so looking for any alternative to vibration hell of wall mounted  TV.
Posted on: 25 November 2014 by GregW
I can think of 2 options:
A simple SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter or an HDMI solution like Atlona's HDMI Multi-Channel to Two-Channel Audio Converter.
With either route consider a USB Y cable (2 x USB, 1 x DC). That way you can use existing USB sockets; perhaps on the TV, to power the converter and thus avoid having to add an extra PSU to your setup.
