MU-SO repeating track
Posted by: Sedagive on 26 November 2014
Hi
When I stream MP3 or FLAC to my mu-so via Jriver media centre 20 it will only play the first track.. continually.
Spotify works fine but not JRiver with the Mu-so as the zone player.
Anyone else had same issue or resolution?
Dan
Posted on: 26 November 2014 by mutterback
Are you clicking on the track or the > play icon on the album cover when you play it? I find the JRiver controls very fussy. I'm using 19, but I make that "mistake" all the time when I click on the track name, it will only play 1 track.
I'm sure there is a setting for what to do if you click on a track (repeat it - which I suspect is happening for you, go to the next one, stop, etc.)  The 1,001 controls and settings are a bit out of hand. Their support forum can be helpful, I'd try that.
Posted on: 26 November 2014 by Sedagive
You nailed it! Set the behaviour to play all, on double click and it works.
I owe you a beer
Dan
