How do you put together an evening's classical listening?
Posted by: JSH on 02 December 2014
Do you just put on things at random or do you put together some sort of "balanced" concert based in key, composers, genres or what?
I'd be interested in views.
Posted on: 02 December 2014 by George J
The great thing about a listening session - of whatever basic type, say classical, jazz or even pop - is that it does not have to be concert length.
Sometimes I have a piece of music running round in my head at work, so after supper, I play that piece. It may be less than ten minutes long, and may even be all the music I play that day.
Another day I may construct an imaginary concert from one conductor and orchestra from recordings made in a reasonably contemporary period, so as to get a sense of continuing style through all the music.
Another day I may start with a solo piano piece, and then go onto a piano concerto and then a symphony.
In other words, though there is shape to my listening there is no fixed pattern or length.
Sometimes I might even listen to four very large [in length] pieces, by varying instruments or orchestras, and that would never be done in a concert.
I am sure that all you need do is listen to music you love ...
ATB from George
Posted on: 02 December 2014 by Bert Schurink
I tend to always start with classical piano, light music, and then switch to more demanding music..., while I have no fixed order and also switch between genres...
Posted on: 02 December 2014 by EJS
It's the other way round for me - first up the stuff that makes the rest of the family run upstairs, then the light music once I have the living room to myself!
(Just kidding - although I do get my best listening in the small hours)
