Unitiqute UPnP server problem
Posted by: prcm50 on 10 December 2014
Can anyone help?
I have a new Unitiqute but can't get any music to steam to it from my Mac mini, I have had music once but after returning a couple of days later all I get is No Servers.
I have replaced my modem/router and have connected by wire but still the same, have enabled Asset UPnP in the firewall but still no luck.
I have my music ripped in Apple Lossless, at the moment I can't think what to do now I never had problems with Air Sream and my Denon.
The Internet radio works fine so I know it's connected. Must be missing something?
Posted on: 10 December 2014 by mrspoon
Try rebooting everything, start with router, then mac, then uniti
Posted on: 11 December 2014 by nudgerwilliams
How old is your Qute?
Qute 1s could not stream Apple Lossless if I remember correctly.
Posted on: 11 December 2014 by ChrisSU
Are your Mac and UQ both connected by ethernet to a router, and is this a freebie from your ISP? Try connecting them all to an unmanaged switch; this may or may not solve your problem, but it's probably worth doing anyway.
Posted on: 11 December 2014 by Phil Harris
AirStream and UPnP are quite different ... when you say you have enabled Asset UPnP in your firewall what do you mean as normally you wouldn't need to add any rules or exclusions in a firewall for Asset. Are you sure Asset is actually running on your Mac and is not simply stopped?
Phil
Posted on: 11 December 2014 by prcm50
Thanks, I have enabled asset in the Mac firewall just in case it was blocking it.
The new modem/router is a new Asus I purchased at the weekend.
The unitiqute 2 is brand new.
I'm not sure how you know if Asset is running it appears in the Mac dock so I presume it is.
Other things like Sky work fine off the new router with Ethernet.
Suggest you click on Asset on the dock to make sure it is running
Ok will try that tonight thanks.
Posted on: 12 December 2014 by prcm50
Well thanks have got things running now, had a 28day trial and asset running in my firewall turned on the other asset and all ok.
The only thing is I find asset a bit blotchy duplicats and missed some music, any ideas I'm using iTunes at the moment?
