Superuniti has stopped playing streamed music
Posted by: tonym182 on 14 December 2014
Hi
I have a superuniti connected by a wired network to a synology ds212j Nas.
This has been playing without any problems using either media server on the disk station or Minimserver on the disk station.
Today I connected via the app - selected either media server or minim server which shows my music folders correctly . I then select a song and it flashes connecting on the su, then the song information shows and then it goes back to the view of the clock - obviously no sound out of the ovator.
It's probably a software update as the dsm updates automatically - this is so frustrating.
I have turned everything off , rescanned using minim watch, restarted all servers but still no sound.
DSM is at version DSM 5.1-5004 Update 2 which updated on the 29th november. I have been away so haven't played the system since about the 26th November.
Also, whenever I use the new app I have to manually add a room for the SU - the old app never gave me any problem.
Anyway the main problem is obviously the non- playing.
Oh, by the way I have checked the synology by loading the elite player and i can select the server and the music plays on the iPad so I'm thinking the SU may have an issue???
Any help would be great.
Tony
PS SU is at v3.22
