UPNP skipping on Muso
Posted by: mutterback on 31 December 2014
Just got a new Muso. Sounds lovely.
However, playing via UPNP, the tracks skip from one to the next and then drop out.
I'm guessing this is a wifi issue. I'm running it on wifi, but have a full strength signal from a Apple Airport Extreme.
Also tried both asset and twonky from a QNAP TS-120, same issue.
Any thoughts?
Posted on: 31 December 2014 by Bart
Try with a wired connection to see if that cures it. If so -- yes it's the wifi.
You can get a 'full strength' signal and still be having problems with interference, etc.  It's not necessarily the signal strength.
