Direct select the Spotify input with remote?
Posted by: ricsimas on 01 January 2015
This doesn't seem possible with the remote, just the app. I wanted to be able to set up a "Listen to Spotify" activity on the Harmony which would not require me to go through the Naim app to do so, but is it possible?
ND5XS, BTW.
Cheers.
Posted on: 01 January 2015 by hungryhalibut
You can choose the Spotify input via the remote (I've just tried it) but it says 'use spotify app' to choose the music. It looks like you are stuck with the app.
Posted on: 01 January 2015 by ricsimas
What input was that, would you remember? I tried all of them and it never selected Spotify.
I'm OK with the Spotify app, I just don't want to go through the extra step of using the Naim app for it (I'm real lazy, I know).
Posted on: 01 January 2015 by Bart
You have to start with the Naim App.  With a properly updated Naim player, Spotify appears as an input along side UPnP, iRadio, USB/iPod, etc.
Posted on: 01 January 2015 by LeeTom
I think it might be possible by looking in Settings->Input Settings or Settings->System Automation... Thought I remembered there being settings to map certain input buttons on the remote to certain inputs.
Posted on: 02 January 2015 by J Saville
Pressing the 'up' or 'down' buttons on your remote will cycle through the inputs (unless disabled in 'Handset Keys' setup menu).
Posted on: 02 January 2015 by ricsimas
Yeah, you can cycle through them, but I don't think you can choose it directly using one of the input buttons on the remote.
Posted on: 02 January 2015 by PG
You can select Spotify as one of the options on the remote by changing the inputs on the main Unit.
I've just assigned Spotify to the AV button.
Posted on: 02 January 2015 by alan33
Also, like with FM and iRadio on the "tuner" button, I think you can overload all the input select buttons to toggle between two sources...
Regards alan
Posted on: 02 January 2015 by LeeTom
Yeah, this is definitely possible using the front screen Handset settings. Assign Spotify to one of the input buttons, then tell your Harmony to use that button.
Posted on: 06 January 2015 by ricsimas
I guess what this shows is that one should read the manual first.
Thanks!
