Coaxial Digital Switch Box
Posted by: Dungassin on 08 January 2015
Posting this here, as I'm not sure how many still look at the Home Theatre Forum, and it is at least vaguely streaming related.
I've been sorting out my AV system, and have decided that I am fed up of plugging and unplugging some of my coaxial digital audio leads due to only having 2 coax digital inputs on the AV2. Looked on-line and can't find a simple box which does this switching, other than one by Bandridge which will also change between optical and digital, but needs to be plugged into the mains. So my question is ...
Could I just use an RCA phono switching box such as the one made by B-Tech, but only use one of the stereo channels? Or would this pose serious problems with impedance matching etc? I have already decided that a splitter type cable is not a good idea as it risks having 2 devices feeding signal to one input at the same time.
Not really needing high quality audio here, just a couple of Freeview PVRs/DVD recorders. I will keep one of the Naim AV2 inputs dedicated to my Oppo.
