Connecting a sub
Posted by: Number 7 on 12 January 2015
I guess it may be regarded as sacrilegious, but I plan to add a sub to my system (Uniti based), and am wondering if the suggested connection method of a couple of the makers I'm looking at (REL) of connecting to the speaker outputs is going top cause any damage? I'm aware that there are 2 sub outputs on the Uniti, but the REL cable with their dedicated sub plug has 3 bare wire ends for connection to speaker outputs. I was also looking for the user manual on the Naim site, but cant find it for this discontinued product. I assume its no longer supported, but is there a source for the manual? (not the quick start guide). I was trying to understand whether selecting the speaker set up options without sub will disable the sub outputs? Thanks.
