Mu so newbie questions-soundbar ? ALAC files?
Posted by: Nerfal on 24 January 2015
Just picked one up yesterday and have a few questions. Can you connect to a smart tv for use as soundbar?
What is the best way to manage and download ALAC files to an iPad or iPhone ?
Thanks!
Posted on: 24 January 2015 by Skip
I use mine as a sound bar via an RCA to Mini plug.    My 2006 Sony XBR TV is not smart.
You can rip your CD's using ALAC into iTunes, then sync with your iPad using the cable that comes with it.  I use AIFF instead and think it sounds better than ALAC.  You can always rip into AIFF and downsample into ALAC to save space on your iPad.   It does not work going from ALAC to AIFF.
Posted on: 24 January 2015 by Nerfal
Thanks. So I found an old Mac w a CD player so I am ripping down a CD now in AIFF as you suggested. Then how do I get the files from my Mac laptop to Itunes or to my Ipad? Keeping in mind this is an old laptop not tricked out with Airdrop or anything fancy to share files across the network….Thx
Time for a new tv bud
You plug in the iPad with the iPad cable into the Mac USB.  iTunes will open and you can drag your files from the library and drop them on the iPad icon in iTunes.
