update
Posted by: mezza on 09 February 2015
hope someone can help I have a problem in that I have tried to update my unitiqute to the latest firmware its failed and im left with the error code 61 its saying it can not find the ip address its etherneted up I have manually entered the ip address but still no joy I have turned off the unit and back on but it just displays failed 61
Do you have both the Qute AND the laptop you're using for the updating connected to your home network? Preferably by ethernet cables to the same router or switch?
The laptop needs a connection to your home network AND a connection to the Qute. And the Qute needs to be connected to the home network as well as the laptop.
To add to Bart's question, have you got the correct driver installed?
first of all thanks to you both for your reply if you mean the driver for the cable yes I believe so the qute is connected to my router by ethernet the laptop wireless I have googled fault 61 to no joy
Your laptop should be wired to the router also. After that re-run the update.
This is not essential. With a reliable wifi connection and an otherwise robust home network, it's fine if the laptop is connected to the home network by wifi. I've done it both ways (laptop via ethernet cable, and via wifi), and they both worked the same for me.
yes I have updated the unitiqute several times in the past with the laptop been wireless I have sen an email to Naim support guess ill have to have it looked at I have re-run the update several times with the same result I don't understand why when the unitiqute is etherneted up its not found on the network
I had the same issue with my uniti and 4.1. I re-installed 3.22 and everything back to normal. Could be something wrong with the update ...
If you are stuck with the "fault 61" message, try the following:
- switch device off
- run the update tool and have it search for your device
- switch device on and do a factory reset
the update tool should redetect your device and offer to re-install a firmware
Hi thanks for your post, I tried doing what you suggest but can not get into settings on the qute and can not reinstall update 3.22 I am sending it into Naim this week for repair hope its not too much as its out of warranty have been told worse case £265 + vat + carriage but I would have the 24/192 board wish I had never tried doing the 4.1 but was only keeping the firmware up to date as Naim recommend
This is really unacceptable IMHO. Updating should not be this long winded, difficult and more importantly risky to the end user. If you have to pay then you are out of pocket and without your system . I have had no issues updating like this but your heart is in your mouth until it reboots.
My two peneth FWIW
ing
Thanks Ing
it will be away for up to 6 weeks that's the worst part lol hate being without my music and the cost of repair to boot, I just hear myself saying if it ain't broke don't fix it , I have updated firmware before without any problems until now
regards
Hello
really need some help not sure if I am in the right place never used anything like this before.
I have a naim set up nac 202, nap 200, flatcap, cd5x with a pair of keff reference series 4+2
the sound is wrong it is not open I want amore balanced and a deeper sound. There is quality there but it's just not right. Don't know what to do to improve it. Do I need a better CD player or different speakers. Looked at running the system bs,acned but according to what I gave read you can't with naim.,
anyone help
Caz
I think you're in the right place But, please, i really don't know what "bs,acned" means.
Hello
anyone help
Caz
What the hell has this got to do with the original thread?
Hello
anyone help
Caz
I think the above has been put in the wrong thread?
Not sure anymore but I think that to do the factory reset, you switch the device off and then switch it back on while pressing the input button.
After a couple of seconds, the device asks to press the mute button to perform the factory reset.
Maybe someone else in the forum can confirm or provide the front panel factory reset procedure ...
Hello mezza,
I do have the same problem with "fault 61" (details described in https://forums.naimaudio.com/to...33#46478590849404333 ) with my uniti 1.
Do you have a hint for me what I could try to unbrick the device? What did you do to get back your qute?
Thank you,
Gert
Hi Gert
I have had to send it into Naim for repair worse case I have been told is £265 + vat plus carriage but for that I would have the 24/192 board
(For the new status of my uniti check the other thread linked above.)
I thought about upgrading to the new streaming hardware, too, independently of the firmware upgrade problem. So I would like to ask if you did hear a difference in sound quality and if the device response more quickly after the hardware upgrade? Is it worth the 400€ I had to pay? (This certainly is a subjective thing. But what do you think?)
Hi Gert
I don't know if ill be having the 24/192 board ill have to see what Naim say the cost of repair is if I do have to have the new board fitted ill let you know when I get my uitiqute back
got my Unitiqute back today from Naim first of all I would like to say a big thank you to Steve Hopkins at Niam for all the help given to me and for fixing the Qute free of charge also a massive thank you to Andrew Oliver at The Audio Republic in Leeds for a first class service from dropping it off there to collecting it today thanks they replaced the streaming board also the front display as there was bleed on it I never noticed it id like to thank you all for the replies you posted
Glad to hear it! Great service from Naim and the dealer ![]()
