Naim DVD5
Posted by: CreativeVision on 11 February 2015
Any (very) easy way to tell if DVD5 has the multi-channel board installed?
Posted on: 11 February 2015 by Richard Dane
Yup, take it to your Naim dealer who can carefully remove the lid and check for you.
Posted on: 11 February 2015 by CreativeVision
Ha, yes good point! Now I'm tempted to prise it off myself and see if anything is actually connected to the 7.1 Analogue DIN sockets I can see on the back...
Be very careful. Particularly with the centre/front locating bolt.  Get this one wrong and you can break the magnesium zinc alloy lid, or punch through the top.  Also, be sure to wear a properly grounded ESD wrist strap if you open up the unit.
Posted on: 14 February 2015 by Manu
iirc, only multi-channel units have the multiple RCA output sockets.
in stereo units, there is a cache instead of center, rear... sockets.
