NDX analogue O/P drive capability
Posted by: Kemills1 on 12 February 2015
Hi
My brother has an NDX and XPS2 power supply connected to a MF nuvista amp. Everything is fine until he connects a Sennheiser hdvd800 headphone amp to the line out of the nuvista. With hdvd switched off, the sound is distorted and quite low in volume. With the hdvd switched on, things are better but still not right. We believe the MF amp is simply routing the source to the line out so the NDX is "seeing" the input impedance of the hdvd.
The input impedance of the hdvd is quoted as 10k ohms and the minimum load impedance of the NDX o/p is quoted at 10k ohms. Although the o/p impedance of the NDX is quoted at 10 ohms it seems to stuggle with a 10k i/p impedance presented by the HDVD.
Has anyone had a similar experience with the NDX?
Sincerely
Kev.
