Nac282 defaults to AUX1 when using app
Posted by: Burgy100 on 14 February 2015
hello people, I hope somebody out there can help me as I have probably hit a button some where and changed the parameters on the 282. By default my ND5 streams through the cd input on the Nac. Now every time I press the iPod button on the app or streamer it defaults to the AUX 1 input and have to toggle it back to the Cd input! This also happens when I start to stream music, I hit play and defaults to the AUX 1 input.
Been trying to figure this out for the last few hours and I am totally stuck. Any help would be much appreciated
Steve
Posted on: 14 February 2015 by LeeTom
It's NOT a setting on your 282. Its a setting on your ND5.
You have recently plugged in a 3.5mm cable so you can control volume of the 282 with an iPad, yes?
Using the front panel and remote of the ND5, you must go into Settings -> System Automation and tell it which input of your preamp you have the ND5 plugged into. (Default is AUX1)
Posted on: 14 February 2015 by Burgy100
Brilliant Lee it was just that. Sorted.... A thousand thanks
Posted on: 14 February 2015 by NaitRider
Hello,
I have been trying to set my streamer (ND 5 XS) at the tuner input on my Nait XS but it is not possible to enable this function, i suppose I am doing something wrong?
Thank you in advance & regards
Thomas
