Spotify om nd5 xs
Posted by: Robster on 18 February 2015
hello i have à problem.
i have update my streamer, but icant get spotify working.
after Thè update i do can select spotify. Than i go to THE spotify app. But i cant select thè nd5xs. It is nog visible.
I have try to update again but with no effect.
somebody has a idea?
robbie from Holland
Posted on: 18 February 2015 by badlyread
Select Spotify on the ND5xs.
Open Spotify app on iPad etc.
Click the speaker logo in the bottom right and select ND5xs.
Apologies if you have already done this.
Neil
Posted on: 18 February 2015 by The Meerkat
Neil
As well as what Neil said, Spotify is a paid service. If you haven't subscribed, you will not be able to use it with your ND5.
Posted on: 18 February 2015 by Robster
Yes i know Thatcher is à pand service, and yes i pay. I also tried several times THE speaker button in the right. Every device in my house i can select except my Naïm streamer
Posted on: 18 February 2015 by alan33
Any chance your nd5 and all your other devices are not on the same network (eg your guest wifi vs your main intranet)?
Regards alan
No imposible, my streamer is connecties with cable to my netwerk. I have tried everything. I now are listening tru sonos connect. Connected whit  specifieke optical cable. sounds ok but prefer spotify true Naïm
Posted on: 18 February 2015 by J Saville
Sounds to me like your router isn't up to scratch. See the sticky thread at the top of the 'Streaming Audio' forum and try the tests.
Posted on: 18 February 2015 by hungryhalibut
I blame Thatcher.
Posted on: 19 February 2015 by Gavin B
For everything!
