HDX skipping tracks with NAS (sporadic but frequent bug)
Posted by: Yvan on 26 February 2015
Hello,
Since months now I'm struggling with my Naim HDX and my Synology NAS (DS412+). My HDX is running on version 1.7b. For a description of the stores I'm using, see the end of this post.
Here's my problem:
1) I can play perfectly my music streamed from the NAS to the HDX during one or two days sometimes, and sometimes just an album and then...
2) suddently during the play of any album, the HDX starts skipping from track to track and plays only 10 to 20, sometimes 30 secondes of each tracks. ![]()
3) at this step, if I try to play any of the albums from my NAS through a simple player on my Win7 computer, it stops reading also after few seconds, saying that there is a problem with the file description. (so this is pleading for a problem on the NAS huh ?
4) but if I lounch a rescan on the Main store, and on the network shares (host scan) through the Naim Desktop Player, it's usually (though not always) solving the problem without having to restart the NAS at all (so this is rather pleading for a problem on the HDX now ! ![]()
If this was happening only with some of the albums, and if it was occuring the same way before and after a rescan, I would say it's the concerned album that has its files corrupted or badly ripped. But as the problem doesn't occur again on an album that was skipping tracks, after a rescan... I guess I can say the files are OK.
My connection between HDX and the NAS hasn't change and is wired in RJ45 Ethernet, double armored. (HDX <-> modem <-> NAS).
Can anyone help me please ? Unfortunately I still haven't found a way to trigger the bug, therefore I'm left with no trail to follow. And it's really painfull to have this wonderful player of Naim that's sporadicly skipping like this when one wants to listen to some great albums ! Is there a way to log the events on the HDX ? or any other idea ?
Thanks in advance !
My stores and network shares are organised as following:
1 folder on the NAS (332GB - 854 folders - 9584 files) used as main store from the HDX with only the ripped music from the NAS on it.
3 network shares: one with (17.88GB - 83 folders - 2208 files), another with (168GB - 943 folders - 9447 files) and the last one with (4,67GB - 20 folders - 123 files).
