Myradio naim and muso
Posted by: musouser on 05 March 2015
I am unable to add radiostations from myradio.naimaudio into my muso.  They simply don't show up in the added stations tab of the naim muso app.  So what i basically do is search for specific stations, i add them to my favourites, and they also show up as my favoirites in the myradio.naimaudio. But they don't appear in the naim app.
Has anyone an idea of what i amdoing wrong?
Posted on: 06 March 2015 by ChrisH
Hi musouser,
I don't have a mu-so, but I found this in the 'Knowledge Base' on the Naim website:-
http://www.netserverapps.com/n...7&category_id=22
If its just a case of adding a station to your favourites / preset when you are in the app on the station in question, press on the star symbol and it changes to a filled star symbol.
You can then find this on the front screen of the app (under where the Input symbols are showing) as Presets.
Maybe this helps?
