Connecting HDX to DAC to Supernait 2
Posted by: Checkthisout68 on 09 March 2015
Hi, I have purchased a second hand DAC today originally from 2012.
I would like to put it between my HDX and my Supernait 2.
So, from DAC into Supernait I take I will use DIN-5.
But from HDX into DAC there a several options.
What is the recommendation?
Thanks,
Chris
Posted on: 09 March 2015 by T38.45
HDX coax------DAC
cheers Ralf
Posted on: 09 March 2015 by Checkthisout68
That should be BNC into BNC then, which is the NAIM DC1 cable, correct?
Right, BNC !
yeah, but both ends? Ex HDX only BNC is possible (besides toslink) but into DAC you can choose RCA or Cinch and NAIM offers both cables: BNC to BNC and BNC to RCA.
Which one is better?
Posted on: 09 March 2015 by Jan-Erik Nordoen
BNC to BNC is the better method of ensuring the required 75 ohm impedance.
Posted on: 09 March 2015 by Chag...
Naim DC1 BNC to BNC.
Note that like any other Naim cable the DC1 is directional. The end identified by the marker "Naim DC1" in black & white should be connected to the source.
Chag -
