vtuner problem ?
Posted by: adca on 11 March 2015
Since two days, iradio on my Unitiqute has stopped playing after some minutes. Pressing "play on the RC or "reconnect" on the app resolves the issue for another couple of minutes. Disconnecting and reconnecting the LAN cable has the same effect. "auto disconnect" is set to "never".
My setup is:  DLink DIR-860L > cat6 > DLink DGS-1005 >
          cat 6 > Vortexbox,
          cat 6 > Untiqute
          cat 6 > Boxeebox
Neither swapping the LAN cables, nor replacing the switch solved the issue. OTOH, streaming music from the Vortexbox (including listening to radio stations using AssetUPnP) works flawlessly. Internet access using the BoxeeBox is no problem either.
Thus, I wonder whether there is an issue with vtuner  - or did I simply miss something?
Any suggestion is warmly appreciated !
adca
Posted on: 11 March 2015 by ChrisSU
Does the problem persist if you disconnect all other iRadio enabled devices, i.e. Vortex box and Boxeebox, then restart your whole network? It's a stab-in-the-dark suggestion, I admit, but it solved a similar issue I had once with my Superuniti.
Posted on: 11 March 2015 by adca
I powered down everything yesterday when relocating the Unitiqute on another shelf. Nonetheless the issue was still there in the morning. I'll give it another try, leaving the BB and the VB disconnected, and report back.
adca
I have powered down and disconnected everything (router, switch, UQ, VB, BB, Amplifier) for several hours. The iRadio now works for about 25 minutes before stopping (VB, BB are neither connected nor powered on). Strange.
Posted on: 12 March 2015 by Trevor Wilson
Hi Adca
Interesting. Can you confirm the following please
Go to settings, factory setting, system status and can you give me the following
Version
Bc sw
This would help me ensure I'm using s similar system to you.
Is there a particular radio station you are using that I can also try?
Posted on: 12 March 2015 by adca
Thank you Trevor. For the next couple of hours, I do not have acces to the devices. Maybe the following is helpful nonetheless:
- The Unitiqute is up to latest specs (incl. BT) and the software version is 4.1 (I performed a factory reset after upgrading from v. 4.0).
- We mainly listen to (news, not music): "RTS La Premiere" and "SRF 1".
adca
BC-SW is: 3D13436
