Spotify
Posted by: Stefan N on 14 March 2015
Suddenly I can't play spotify on My cute. The qute says "ready connect Spotify app" but in My app the qute doesnt show. Please help.
You need Premium Spotify, and you click the green icon to activate it.
I know it sounds silly but have you tried turning the unit off and back on and resetting app by force closing it or turning pad/phone off I usually find this helps on my muso or my unity when they play up
Spotify updated yesterday has this only happened since then if so try uninstalling and reinstalling spotify other wise I have no other suggestions I'm afraid sorry
Last idea turn your router on and off my iPad glitches all the time on my wifi I have to keep turning on plane mode and then off to get it to respond properly and occasionally reset my router
My unity is run off Ethernet cable and still locks up resetting my router fixes it
No IT didnt help. I must be missing something.
Now it is working again. I disabled the input again and now it's find. Thames for your help.����
That's OK, water under the bridge!
I have the same problem since a some days. Suddenly when I select "unity" from my spotify connect and play the song then cannot find the unity anymore. I have tried resetting iphone, app, unit, reuter... re-installing spotify... not sure if the problem was after the app update or something in my setup. Any ideas? Thanks,
I have done the last trick - resetting my uniti to factory settings - and now Spotify connects works again
