Mu-so & Hard Drive
Posted by: myNaimisMark on 17 March 2015
Hi all
If I connect a powered hard drive containing FLAC files & artwork for each album, will the Mu-so find them and play them ok and display the artwork on the app? Or will I need a NAS drive with some software on it?
Sorry about my naivety, it's all new to me...!!!
Cheers...
Posted on: 17 March 2015 by nudgerwilliams
The manual says this:
The behaviour of USB devices connected to mu-so, and
access to audio files they hold, varies depending on their
type.
Audio files stored on USB memory devices can be browsed
and selected for playback only by using the Naim app.
Once playback is underway however the mu-so touch panel
and handset can also be used to select play/pause, next or previous
Note: Most UMS (Universal Mass Storage) USB devices
are compatible with the mu-so USB input. Mobile devices
using the Android operating system are not compatible
So I think the short answer is yes, probably.
Posted on: 17 March 2015 by nkthomson
I tried my WD My Passport portable hard drive and it didn't work.
Posted on: 17 March 2015 by Stampie
If I remember correctly, you need to use UPNP to get album art across all Naim's streaming products, not just muso.
I just tried a FLAC album on a USB stick and no album art in naim app.  Same with Airplay. uPnP provides the album art.
