WARNING: major trouble with streaming firmware update 4.1
Posted by: gerdh on 21 March 2015
I updated my NAC 172 XS to firmware 4.1 to get spotify connect.
The consequences for my iOS Naim apps are catastrophic:
1. i cannot switch input anymore - the buttons light up on touch but do nothing
2. I cannot play upnp tracks or albums anymore
3. volumen control is not working anymore
4. Every three seconds the screen of iOs Naim app shows a rotating cirlce, then rebuilds wiping out any menu or dialog I had open at that point.
Of course I tried EVERYTHING:
- deleted and reinstalled the app on both my iPhone & iPad
- restarted my iPad
- reset all settings on the NAC
- rebooted NAC several times
Above symptoms showed both on my iPhone and on my iPad right after installing firmware 4.1.With the current behaviour my streamer is literally useless since I can only use it from its frontpanel.
Is there anybody out there haveing the same experience after installing 4.1 ?
Is there any clue how to resolve the problems ?
Is Naim aware of those problems at all ?
Is there a bugfix version of firmware 4.1 in the making ?
Posted on: 21 March 2015 by Bart
Have you reached out directly to Naim Tech Support?
Given that this has been released for quite a while now and the world has not caved in, your experience is not UNIVERSAL.  I'd start with Naim Support.
Sorry to hear of your troubles; they are certainly frustrating when they happen to any owner!
Posted on: 21 March 2015 by gerdh
Amazing:
One day and a dozen restarts/reboots later the problems simply have dissappeared.
Must have been some strange network hiccup btw. the NAC and the router !?!
Yipppie I got my NAC back - now Spotify rock me...
Posted on: 21 March 2015 by sjbabbey
The latest firmware update forced a factory reset which was probably at the root of your problems e.g. system automation would have to be set up again etc. although I see that you did try resetting your settings.
Glad to hear you've managed to sort it out.
