Recommend chill out iradio stations
Posted by: Funk1600 on 22 March 2015
Enjoying iradio on my new Unitiqute2.
Are there any quality chill/laid back music stations that you guys enjoy?
Also could anyone recommend a good premium streaming service must be atleast 320kbps.
'Bossa Nova Breakfast' ...early morning weekends with nice coffee...but it's Monday!
- Radio Schizoid Chillout
(Ambient India) 128kbps
- Cafe Del Mar. FM
(Electronica UK). 128kbps
- Hi on Line Lounge Radio (Ambient Netherlands) 320kbps
I will look into these
There are of course reasons not to favour Spotify or indeed streaming services in general, but if you're happy with 320, it's hard to beat.
Theres me thinking that the OP was asking for radio stations .........
There's me reading the rest of his post and the bit asking about streaming services ![]()
Dont you need the spotify connect version of the UQ2 for spotify streaming?
If you've got a UnitiQute 2, but it doesn't have spotify connect, there's a firmware update available which will enable it.
There can be issues with older UnitiQute 1 models, but any UQ2 should be able to be updated to use connect.
Can I update it myself or only dealer is authorised to?
Any Uniti or ND series product can be updated with the 4.01 software downloaded from our website and the 24/192 units will support Spotify Connect functionality when used with a Spotify Premium account.
Best Regards
Phil Harris
Just to confirm, yes, you can do it yourself, you don't need your dealer to download & install it for you.
There are instructions in the download package, and if you look back through the forum you should find a few threads talking about the process. The last update (which was the one which introduced spotify connect) wasn't too long ago. If anything does go wrong - which is fairly unlikely if you follow the instructions properly - then your dealer should be able to help.
Thank you
frequencies relaxation - calm radio
When I enter the mac adress at http://naim.vtuner.com
Keep getting cookies are not enabled.
I double checked cookies are ENABLED.
Tried two different Pcs
ANTENNE BAYERN - chill out
ARCTIC DUB SURCOMCORDA . Without a doubt the best chill out station of all time ....
