inernet radio UnitiServe
Posted by: Mac Spike on 23 March 2015
hi at all,
i cannot access my radio preset or any internet radio on my Uniti Serve (firm. 1.7b) .
N-serve 2.9 is crash.
Can you help me?
Posted on: 23 March 2015 by PBenny1066
Mac,
have you confirmed that the US has an Internet connection ? If not I would try to establish this first....
Several ways possible, in IOS for Mac there is a status for Internet connection, .......alternatively just try to rip a CD and see if the U.S. performs an online look up of the AMG database, ..... or pick a CD and try to look for a new album cover using the edit function.
Posted on: 23 March 2015 by ChrisSU
Did it work before and just stop, or has it never worked? How is it connected to your network and hifi?
Posted on: 24 March 2015 by Mac Spike
Userve has stopped working three weeks ago .
Router and userve are connected with Ethernet cable, ripping working properly as well as the connection to the database amg.
Internet radio does not appear on the menu n-serve 2.9 / 2.8 is only present in version 2.7.7147.
Even on desktop client voice radio is disabled.
Posted on: 25 March 2015 by PBenny1066
Are you running the latest firmware on the US ? If yes, not sure what to suggest other than a call to Phil Harris at Naim who seems to be able to sort out almost anything....
