ND5XS display kaput
Posted by: Nagual on 26 March 2015
Just got home to a jumbled screen on my unit. Tried the on off trick now the display is solid green every pixel. Anyone else encountered this? Unit sounds fine but looks like it needs a trip home
Posted on: 27 March 2015 by james n
Might be worth a search, but IIRC there were threads on display issues on these units which was down to a connector on the ribbon cable between the main board and front panel needing re-seating.
Posted on: 27 March 2015 by Nagual
ah right, thanks for that James i wasn't aware of an issue. Ive emailed some photos in to HQ but pretty sure it needs a visit.  I will speak to my dealer at the weekend and drop it off.
Posted on: 27 March 2015 by gary yeowell
I had a flickering LCD on my previous Qute1 which randomly lost parts of the display. I was set to ship it back to Naim when without doing anything  except turning it off for a few hours, it rectified itself and never occurred again.
Posted on: 30 March 2015 by Nagual
thanks Gary I did try leaving it off overnight then back on.  Even less of the display was awakened.  Had a very quick reply from HQ saying that it was probably homesick and needed a visit so dropped it off to the dealers Saturday.  Fingers crossed for a speedy return.
Posted on: 30 March 2015 by Jumping Jack
The ribbon-cable in my NDX disconnected once after the unit came back from service (probably due to an overactive courier). The screen would'nt light up, only the right and the down arrow button did.
I had to send it back to the distributor (Latham in Holland) to get it fixed, and then they had it deliverd back to me by one of their one technicians. Great service!
Posted on: 31 March 2015 by Harry
I've had two screen faults with the NDS. It's likely (but never certain) to be a cable or logic board.
Posted on: 31 March 2015 by JohnL
I have had a "bleeding" display on my NDX. Had to go back to Salisbury, apparently a ribbon cable that comes loose on earlier models. As ever, corrected by Naim and no trouble since.
John
