Spotify or flac files with naim Muso
Posted by: soub on 31 March 2015
Salut,
Je viens d'acheter un Naim Muso. Il fonctionne bien, mais je ai l'impression que le son est meilleur avec Spotify (câble Ethernet) que avec les fichiers flac (VPN) et foobar2000. Je me demande si il semble logique de vous. Je pourrais essayer avec un NAS mais je ne sais pas si cela a une influence sur la qualité sonore. Si vous avez quelques conseils pour effectuer son avec les fichiers FLAC.
Merci
Posted on: 31 March 2015 by Dave***t
I'm not sure what you mean by VPN as opposed to Ethernet. Surely it's possible to connect to a VPN via Ethernet? But regardless, FLAC files certainly should sound at least as good as Spotify. Most people think they sound better.
Have you tried playing FLAC files from a USB stick? That should eliminate any network issues and narrow down any sound quality issues to the files themselves.
Posted on: 31 March 2015 by Tony2011
Couldn't be bother to write in English, could you?
Hi,
I just bought a Naim Muso . It works well , but I have the impression that the sound is better with Spotify ( Ethernet) as with the flac files (VPN) and foobar2000 . I wonder if it makes sense to you . I could try with a NAS but I do not know if this has an influence on the sound quality. If you have some tips to make sound with FLAC files.
thank you
