OSX M.Lion or Yosemite
Posted by: sheffieldgraham on 06 April 2015
I have recently purchased a Garmin Sat Nav.
It requires OSX 10.8 or newer to update maps etc.. I have 10.6.8 Snow Leopard.
Should I purchase M.Lion (chargeable) or download Yosemite (free).
Mavericks doesn't appear to be available.
I'm asking In view of the reported problems some forum members have had with Yosemite.
I welcome your opinions.
Graham
Posted on: 06 April 2015 by ChrisSU
+1 for Yosemite (especially if it's free and ML isn't.) There are a few minor issues that annoy me, such as clumsy a few navigation features that never existed in older versions, but on the whole I've found it stable and trouble free so far.
Posted on: 07 April 2015 by Southweststokie
Graham
In the stokie household Yosemite is SH1T and we wish we had never moved from Maverick. Still can't get some emails to work due to changed protocols on passwords, wifi drops out and the endless beach ball on safari, none of this happened with Maverick and I doubt it would be happening at all if Steve Jobs was still with us
Posted on: 07 April 2015 by Peter Dinh
Graham
Seems to me that you may have some kinds of DNS issues. Flushing the DNS cache may or may not resolve your issue, but I think it is worthwhile to try it.
If you want, I can send you some instructions on how to do it, one thing is that you need to be comfortable with the command line on the Mac Terminal.
I think Yosemite is fine, it is much better than the prev Mac OSes in all aspects IMO.
Graham
Peter,
That's appreciated but I am no computer expert and doubt I would risk messing with things I don't know enough about to start meddling with it and bugg..ing it completely.
Ken
Understood, I would recommend taking it an Apple store, explaining your problem(s), hopefully they can fix it for you.
It is a really a pity that you suffer some network issues, you don't need to You paid for it, so you deserve some good services.
Originally Posted by Wat:
Ken
Definitely worth a trip to Apple Store for some help. I haven't experienced the e-mail issue though some domains are not considered secure by Apple, it usually just warns and proceeds if you choose not to accept Apple's view. I have found Google Mail and Apple's iCloud mail rock solid - what e-mail domain are you using?
If you want to clear DNS caches then you just need to copy and paste this in to a terminal window, hit return and enter your password when prompted - it'll tell you when it's done (worth a go) - it's all on one line.
sudo discoveryutil mdnsflushcache; sudo discoveryutil udnsflushcaches; say flushed
Wat
Hi Wat,
Before I try this, how do I go back if it does not work or i screw things up?
Posted on: 08 April 2015 by Peter Dinh
Wat has not responded yet, but I guess I can help here. Basically, these commands just clean the caches and you cannot get them back. You just cannot go wrong with these commands, they just clean junks from your computer.
By the way, 10.10.3 (new Yosemite release) just came out today, you may want to upgrade to this version and see how it goes.
Posted on: 09 April 2015 by Southweststokie
Hello Ken
Peter has already answered: a cache is a temporary store of information & so clearing it will not cause any problems. Your Mac will rebuild the caches. Clean up programs generally clear out all kinds of caches & so doing is perfectly safe.
I would also upgrade to the latest Yosemite release.
My biggest problem with Apple upgrades was installing them when I used BT Internet. It got stuck at around 800MB. I overcame this by using a cloak (remote proxy). Since changing ISP, this problem vanished. I've never understood why it ocurred. Pre-Mavericks upgrades were never an issue. These odd things are sent to try us & so we don't become complancent that everything just works
I hope this solves your mail problem.
All the best, Wat
Peter, Wat,
I will give it a go but will update 10.10.3 first.
Thanks for your advice,
Ken
Posted on: 09 April 2015 by sheffieldgraham
Hello Ken
All the best, Wat
Peter, Wat,
Ken
Ken,
        Let us know how the update goes. I hope it resolves your problems.
Graham
Posted on: 10 April 2015 by Southweststokie
Ken
Wat
Hi Wat,
Just tried it but it comes up with the following warning and will not allow me to enter my password.
WARNING: Improper use of the sudo command could lead to data loss
or the deletion of important system files. Please double-check your
typing when using sudo. Type "man sudo" for more information.
To proceed, enter your password, or type Ctrl-C to abort.
Password:
Posted on: 10 April 2015 by Peter Dinh
Is your account type 'Admin'? If so, just enter your password and press return. Please note that you can't see what you are typing for security reason.
If your account is not Admin, you will need to switch to an Admin account somehow.
Some settings can only be changed by the Super User (i.e. the master administration account that is all poweful). An ordinary user can run commands that are usually restricted to the Super User by using the   Super User DO command (sudo) this requires you to enter the Super User password. If you were the one who set up your Mac in the first place then the Super User password and your password will be the same.
There are command you could run using sudo that would indeed do damage, but the ones we have provided are prefectly safe. The password is the local user one, not your Apple ID password. Do you log on with a password or use automatic login?
Hi Wat,
I set up the Macbook from new I also use a log on password from start up and sleep. is this the password you refer to? My wife is the only user of her Macbook and she set it up from new, she has experienced the same problem, she get the same warning message and it does not allow a password to be entered.
Ken
Posted on: 11 April 2015 by Southweststokie
Ken
Yes that is the password
using sudo will always display the Apple disclaimer ... as Peter says, when you enter a password it will not show anything on the screen so may appear as if it is not doing anything Or accepting what you type. However as soon as you press return the commands should run. As you get no feedback when commands work in the terminal window: I added the say command so it announces it has done. The password is the one you log in with and should have admin rights as it is the one you used to set up the Mac. I have also pasted in some notes regarding a gmail quirk I'm aware of. However, if not using gmail then this is irrelevant. I use gmail and iCloud mail and luckily everything just worked. I use the Apple mail app on my Mac and sync my mail to my iPad and iPhone through iCloud.
I would echo Peter's comments that the guys in the Apple store are very helpful and will help setup mail if you still have issues. Sometimes it is easier to fix these things sitting at the Mac in question. It does seem to me that this is an issue with Yosemite and your mail provider as you and your wife have a similar issue on different Macs. Which mail provider do you use? I'm only familiar with Apple (iCloud), Google (gmail) and BT (btinternet). I've got all of them working: though am phasing out my use of BT services, as I wish to rationalise and only have two accounts (one acts as the emergency recovery for the other).
all the best, Wat
<code>> sudo <commands>
WARNING:Improper use of the sudo command could
lead to data loss or the deletion of important system files
Please double-check your typing when using sudo.
Type"man sudo"for more information.
Password:
</code>
There were odd problems with gmail that can be solved as
follows (it takes a few hours to rebuild gmail)
  • Open email client app on your Mac computer.
  • Log into Gmail in your web browser, not in the app.
  • Look for a button on the right top corner of your Gmail that looks like a gear and click on it. Then click on Settings.
  • Click on the choice for Labels.
  • Deactivate Show in IMAP as well as All Mail and then return to your inbox to save settings.
  • Now, close the mail client app you have open for Mac.
  • Go to preferences on your Mac computer and choose Internet accounts. Delete all Gmail accounts now.
  • Go back to your Gmail account, to the settings as described in steps three through five.
  • This time, reactivate Show in IMAP and All Mail.
  • Now, reopen your Mac mail client.
  • Go once again to Preferences and choose Internet accounts as you did in step seven.
  • Add back your Gmail accounts now.
Wat
The email account I have a problem with is with Plusnet. I have opened a gmail account and transferred all my important mail contacts to this one. The gmail account works fine. I am more frustrated now with the sudden wifi drop outs and the the beach ball delay in Safari. I will try your advised solution again.
 Thanks,
Ken
Ken
Wat
Wat,
I have tried it again and typed in my password as advised but nothing happens.
Ken
Ken
Wat
Wat,
Ken
Wat
Just tried it yet again, now I do not get the option to enter my password?
Ken
Ken
Wat
Wat,
Ken
Wat
Ken
Wat,
Perhaps I am not understanding what has happened. I think it has cleared out the cache as when I try it again I get the verbal response "Flushed". So I think it has cleared out the cache, is this correct? Sorry to appear so dumb but computers are not my strong point. I'm more at home with large steam turbine thermal turbo machinery which I worked with in the power generation industry for the best part of 40 years.
 Ken
Posted on: 12 April 2015 by Peter Dinh
Ken, you can go here (http://osxdaily.com/2014/11/20...-dns-cache-mac-os-x/), and it will tell you what to do, and what is expected.
How does your machine look now? Better? Btw, I suggest you upgrade to 10.10.3.
Posted on: 12 April 2015 by totemphile
Graham, you can buy an OS X Mavericks USB stick on ebay and do a clean install that way. Most of the people selling these sticks are stating clearly that they are selling their labour time required to prepare the sticks, rather than the software, which of course belongs to Apple. There is at least one seller in the UK, otherwise check the German site. Just make sure you do a time machine backup before you format your HDD.
tp
Hi Wat,
I hear you. I was only mentioning what they "charge" for to be on the safe side. Of course they want to make money of it but have to put a caveat in to guard against copyright infringements. Whether that's a watertight business model, is of course debatable
I am a Snow Leopard user myself, MBP mid 2010, and have been pondering to upgrade or not. I don't like to candy coloured icons that come with Yosemite, hence I explored how to get Mavericks and came across them USB sticks on the bay. It just so happened that my MBP developed the black screen / out of nowhere shut down syndrome, which the mid 2010 motherboard has been prone to - a faulty NVIDIA GeForce GT 330M graphic card is the source of all evil. So I am having doubts about whether an upgrade to Mavericks / Yosemite will exacerbate the problem or not? Don't know. Unfortunately I missed the cut off date for the warranty programme Apple had in place and have to live with it for now. It's a nuisance more than anything but not so bad as to render the MBP useless and force me to buy a new one. Not yet at least.
ATB
tp
Posted on: 12 April 2015 by Southweststokie
10.10.3 upgrade is done. My Plusnet mail account is still no better but I have opened a gmail account and transferred all my important contacts to it. I am monitoring my Macbook performance to see if it is improving. No wifi drop out or Safari beachball so far.
ken
My Plusnet mail account is still no better...
Ah, since you just mentioned Plusnet email account, now I understood your issue - it  is a very well known one due to an out-dated Plusnet way of doing things, and there is a fix for it, please read this discussion on how to fix it (https://discussions.apple.com/...tart=30&tstart=0). Basically I think this is what the guy did to resolve his problem:
"Quit mail
Open up Finder
In the Finder menu bar select Go > Go to folder
type in ~/Library and click Go (on my keyboard the "~" is next to the left shift key)
Open the folder Mail
Open the folder V2
Open the folder MailData
Double click to open Accounts.plist (should open in TextEdit)
Find the block of data that contains the offending mail account
Find the line within this block that says UserAllowsInsecureAuthentication
Change the line below this from to false to true
Quit TextEdit
Restart mail"
"Quit mail
Open up Finder
Open the folder V2
Quit TextEdit
Restart mail"
Peter,
I can make the account work by going into Preferences and ticking 'allow insecure authentication' and ensuring 'use SSL' is un-ticked. But is this a safe way to use the mail account?
Ken
No, this is not safe, but apparently according to the Plusnet users, this is a bug and Plusnet has to resolve it.
It is your call to go on with your Plusnet account, I would go for google email or something else.
Btw, as I do not use Plusnet, I am not sure by going to Preferences, ticking off SSL, etc. would make it work, but I guess you could find that out easily.
It does work, but I have move all my important contacts to a gmail account which works fine.
Ken
Posted on: 13 April 2015 by Derek Wright
I use PLusnet based email addresses on a fleet of Macs and iPhones all on the latest OSX and IOS.
I have a set of email addresses on GMAIL, all email received on the PLusnet based email addreses is redirected to the GMAIL addresses.
AS mentioned above I am on Macs. I use Thunderbird mail product that collects the email from the Gmail accounts. I use the IMAP mail protocol and have designated by my way of working that I only save mail on  the primary machine - a Mac Pro, I can delete trivial mail on any machine and it gets deleted from the rest of the fleet.
I have set on Thunderbird the reply to address  to my Plusnet based address.
I have found the Gmail spam detection system to be pretty good, I am not dependant on the Plusnet processes for email apart from re-routing the mail direct to Gmail.
I also have set up about 8 email addresses based on my Plusnet email address which al get rerouted to GMAIL.
