Help with multiroom please...!
Posted by: sjw98 on 06 April 2015
Hi all,
I can't work out how to set up multiroom (i.e. play the same thing from two naim streamers)... is there actually a way?!? I'm either being monumentally thick (very possible) or it's really not obvious.
I have an NDX and a mu-so. When I go to "rooms" on the NDX and go to my muso it says: "Room did not respond. Check power and network connections and stop HD audio playback".
Both are wired with static IPs, and both, alone, work perfectly! Is there something I'm meant to do on both? Can I do it from the iPad / iPhone app? Is it even possible?
Thanks in advance.
