Unitiserve flac reproduction problem
Posted by: MikeK on 17 April 2015
Hi to everyone,
I own a fresh unitiserve 2tb and I have a few problems with flac reproduction.
The connection I use is unitiserve to audiolab m-dac with naim digital cable and from m-dac to naim nac282 with other digital cable.
The flac files are saved at the internal hdd, in the downloads folder, at their own folders per album.
So, my problem is that, when listening to them, there are times that the audio is not gapless, but stops for a second and continues.
This is not often.
If I stop the music and restart it, I might not have the audio gap of that second.
There are times that I listen to the same files and the audio is gapless.
Are there any settings to change that might correct the problem ?
The problem is not constant, why is very strange...
Posted on: 17 April 2015 by hungryhalibut
Try setting the Serve to transcode to WAV and see if that fixes it.
Posted on: 17 April 2015 by MikeK
Does it have to be set up, even if I play the files directly from the unitiserve ?
I thought that these affected only when playing the files of the unitiserve's hdd to another device, for example from a pc through network.
Yes it does- you do it via the DTC.
