HDX/NS01 FILMWARE 1.5?? MISSING
Posted by: steven2907 on 12 May 2015
I need to upgrade my NS01 filmware from 1.4b  sp5 to 1.5 then the rest of the update discs   I hae checked the download page and its showing version 1.5, click on it though and it downloads 1.5a sp2.....any ideas??
Also a BIG thanks to the people at Naim, I contacted them yesterday and today regarding my NS, they have been very helpful...Just got to get it upto date now
Posted on: 13 May 2015 by Richard Dane
Steven, as you have been in contact with Naim, I would suggest you speak to them again if you're unsure.  FWIW I looked at the firmware page and 1.5 is listed as 1.5a SP2. So this looks like it's fine. Just ensure you are on 1.4 before updating to this.
Posted on: 13 May 2015 by steven2907
Thanks Richard .  I did mention the fact that 1.5a when opened shows 1.5a  sp2 to Phil Harris.  His answer was you need 1.5a first.
Hence the the reason I am asking the forum as Phil is a busy man
thanks again.
thanks again.
Hi Steve,
Yes, from 1.4b you will need to go to 1.5a then to 1.5a SP2, 1.6b, 1.6d, 1.7a then 1.7b ...
Best
Phil Harris
OK, well Phil should know so I'll defer to his better knowledge here.
Posted on: 13 May 2015 by Phil Harris
I sent him a link to the 1.5a firmware files this morning...
Phil
Posted on: 14 May 2015 by steven2907
Thanks phil/Richard.   All sorted now.  Only took 5 days. The link you sent helped a lot,
   Steve
