HDX crashes on LAN / DLAN
Posted by: Checkthisout68 on 13 May 2015
Hi there, I am still working on the HDX issue. My HDX goes into "please wait" mode after a couple of days. Remote PC maintenance by Naim Germany did not reveal any technical problems.
They have asked my to check and use a direct connection between the HDX and the router and so I ran a long cable all through the living room. Same problems occurred after 3 days, frontend crashes and no network access to the HDX.
I found out the HDX only runs in 100Mbit mode as opposed to 1Gbit, although all ports on my router are in so called power mode ( no green mode, which makes it use 100Mbit only). The cable between the HDX and the DLAN power line adapter used be to 7m, the other cable I tried between HDX and router used to be around 10m.
However, I have now tried a brand new cable which is only 5m long between HDX and Powerline adapter and it turns out the HDX now runs in 1Gbit mode, says the router.
Questions:
1. Does cable length cause such problems? Is more than 5m too long?
2. Does the 100Mbit mode cause crashes on the HDX network interface such as I am experiencing?
Best
Chris
